RCU Forums - View Single Post - RF Ignition Interference
Old 02-08-2005 | 07:02 PM
Diablo-RCU
Default RE: RF Ignition Interference
If you get radio interference when you throttle up your gasser, I would bet the problem is metal to metal vibration, and it doesn't have to be the throttle pushrod. It can be anywhere on the plane - like elevator pushrods using a metal clevis and no locknut. The radio pulse put out by the ignition has the same energy at idle as it does at full throttle - only the frequency will increase with rpm.
