http://www.onlineconversion.com/volume.htm
select your units on each side and type in the amount at the top.. hit convert. This site will do everything from length, volume, and entergy to clothing, currency, and other crazy stuff.
In the case you are talking about.. use volume and select cubic inch and cubic centimeter.. unless you really meant cu.. I don't know what that means.
