RE: Flair Puppeteer Trust Angles
Wow, thanks Bassman. I had no idea they were wanting you to use the covering as the hinge. I am confused still about part 73, wich they will have you make as the ends of the airlerons. Do I just leave those out and use the rib ends to finish the ends of the airlerons? I know part 73 with the nut soldered on would have to stay there, but the other part 73 used for the rib ends looked off centered on the left plan. I assume everything would have lined up once everything is cut. So in other words, use my knowledge and imagination to improve their plan and make a regular, modern airleron?
Thank you so much any more help and info would be appreciated.
