RE: Flair Puppeteer Trust Angles
Bassman, I want to thank you again. I just created the Airleron Cutout per you instructions. This is what I did. I use the ends of the cut ribs for the ends of the airleron, and used 1/16 in spacers between those ends and the wing edges where the airleron goes. That'll leave me a nice 1/16 gap and once it's cut out, I'll clean up all the ends and edges. Then I'll add the TE wing stock per the kit, then add my own leading edge airleron stock and angle it to have a nice modern day airleron that uses normal hinges.
Thanks again,
Joe
