RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Thread
02-09-2005 | 06:49 PM
196
8178
My Feedback: (
17
May 2004
4,351
Atlanta, GA
RE: Howard Engineering - Kwik Fli III – Build
The kit uses a clever plywood tongue to hold the front of the wing, but because I’m using retracts and needed the wing cutout I’m using two dowels. The wing dowels were glued in using lots of 30 minute epoxy inside the holes at the root of the wing. The dowels were coated completely with epoxy and then wiped clean before insertion into the wing. All the epoxy inside the hole makes good contact with the dowel after it is inserted. The coat of epoxy on the dowel will keep engine oil from soaking into the dowel and create a strong bearing surface. After the dowels were in place the wing was installed on the fuselage and bolted down to hold the dowels in place while the epoxy setup.
To be continued..
Reply
Like
8178
View Public Profile
Send a private message to 8178
Find More Posts by 8178
View iTrader Profile
