RE: dual sensor starting ignition
On a CH ignition you would switch the white wire on the sensors.
Some choices, Big start/run switch to be flipped after starting.
Micro switch hooked to throttle, at some point above idle the run sensor is turned on. Disadavantage to this is a big change in RPM as you blip the throttle trying to land.
