regular voltmeter and onboard?
hey guys, just getting back into it after8 years.
I can't find my old voltmeter to check my reciever pack at the field. I remember when we used to fly with my dad we never checked them. But we were usually alone in the cowpasture. But at the local club here there are usually people there and I would like to keep a monitor on the reciever pack.
so my questions are?
1. do most of you regularly check you reciever pack at the field? and how often? 3 flights 4 flights or minutes used?
2. Not looking to spend alot of money but what voltmeter is cheap and easy to use? I have a futaba skysport 6channel with standard reciever pack. 600mah. I will be flying a super sporter 60.
3. I have seen these on board flat votmeter things i guess you stick on the side of you fuse? does anyone use these?
thanks
