RCU Forums - View Single Post - HELP!!! Maiden flight right off
Old 02-10-2005 | 05:45 PM
  #40
RedWing
Default RE: HELP!!! Maiden flight right off
I am in agreement with DBCherry, Fourstroke and Bruce.
I have this plane and giving it rudder will roll the plane. Once off the ground use your ailerons.
Get used to using them.
Also, make sure you are on with your CG.
My CG is right on and even a little back, it flys great.
Although you can get this plane to hop off the ground on takeoff, keep it on the ground and lift off slowly. Get it up, keep it straight, get some altitude then start your first turn. Remember, fly the plane, if you need to trim it don't sacrifice flying. You may only get to get a few adjustments on trim per fly by. That is ok, just keep flying and compensating if it is out of trim.
I know mine flew great, only a few clicks of aileron.
Bill
