RCU Forums - View Single Post - Warped foam wings
Old 02-11-2005 | 08:44 AM
GuyIncognito
Default Warped foam wings
I need some help with my warped scratch built wings. This is not the first wing I've built. This time I followed all kinds of advice. It's a Typhoon wing. I honey combed it - but not too much. I reinforced it with two strips of fiberglass window screening (ala the Temptation). I used Elmers Polyurethane glue. Put lots of pressure on the shucks to set. Used 4-6 lb. balsa from Lonestar, etc.
After I removed the wing after 24 hrs it was very bumpy (seems to be over the honeycomb holes and the screen strips) so I sanded it a lot until it was nice and smooth and voila, a nasty warp appeared. At least 1/4 of an inch + from root to tip.
Is there any way to rescue this wing. Am I doing something wrong? Ive had this happen to ailerons after they were cut from the wing but not to a whole wing. I've put a lot of work in this plane and don't really want to start the wings all over. I've thought about soaking the balsa in ammonia and putting it back in the shucks but when I've tried this on stabs etc. it just doesn't work well.
Can anyone point me to an appropriate thread or provide some advice. I'm going NUTS.
