RE: Problem with my Mayhem
You said you changed out the shoes....did you change out the springs as well? If you ran it for a short while while the clutch was giving you a problem the springs will heat up excessively and loose their strength i.e. ability to hold the shoes down until the motor builds more revs. If you didn't, that's probably the prob'. Springs will typically need to be replaced at the same time the shoes are replaced for best performance.
