RCU Forums - View Single Post - Stripped Wheel Collar removal?
Old 02-11-2005 | 06:37 PM
Campy's Avatar
Campy
Default RE: Stripped Wheel Collar removal?
When you drill out the screw make sure you use a VERY HARD drill bit or you will dull it before you ever get the screw drilled out. I suggest a SOLID cobalt or SOLID tungsten drill bit.
A couple of words of caution/advice - They are not cheap and they are brittle.
You should seriously reconsider cutting them off. A few seconds with a cutoff wheel on a dremel will do the job. Wheel collars are cheap. Even if you drill it out you will not be able to reuse it.
