RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 02-11-2005 | 08:50 PM
  #730
rcjon
Default RE: Vectorflight Edge 540 build
Guys,
Tonight I worked on installing the tail brace wire kit (Sullivan Flying Wire/Tail Brace Wire kit, No. S546). I used the stainless steel cable AOT to the Kevlar. In typical male fashion, after I was through I read the instructions carefully. Before starting I just looked at the pictures.
There, the very last paragraph of the instructions reads:
"These wires can be used on any part of the model. It is often good practice to "break" a closed loop with something nonconductive to avoid an antenna effect."
I assume that has something to do with the dreaded "RF Interference".
My tail brace set-up currently forms a four sided loop that is all metallic, just like the picture on the front of the instruction booklet, except I only put clevises on the wires under the tail.
Should I put nylon clevises on this set-up?
