RE: Wildhare Extra Special engine placement help?
I have the spinner flush with the top, and centered side to side. The engine is offset to the left so the propshaft would be centered.(due to the right thrust) I also enlarged the mounting holes in the cowl slightly and used those washers that have rubber bonded to them so that I could fine tune the spinner to cowl gap. Hope this helps
Brian
