RCU Forums - View Single Post - New Switchback!
Thread: New Switchback!
Old 10-16-2002 | 03:56 AM
E-Challenged
Default Switchback info 3D version
I simply mounted the lg backwards and bent the gear legs forward, wheels slightly towed in. ROG's need a little right rudder due to torque.First flight, needed a little up trim, a tad of aileron trim. After trimming, plane flies smoothly, not twitchy. Eight 720mah NiMh Cells and GWS 300C(B) with 9X7 prop give 10+minutes at average 3/4 throttle, Flies inverted at 3/4 throttle with just a little down elevator. Landings are light and easy even dead stick ( cutoff occured at about 12 minutes). The sport wing option is nice but don't thik you'll need it if you have any aileron experience. Mine weighs 13.6 ounces with the NiMh pack. Maiden flight was yesterday morning, flew even after wind kicked up to about 15mph, handled very nice. Caution SB is addictive!
