RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 02-12-2005 | 08:11 PM
  #738
RBgunner
My Feedback: (8)
Default RE: Vectorflight Edge 540 build
Nathan, stick with it, you will get your Edge up when the time is right. At least that is the way I look at it. I had hoped to maiden my Edge well before today, but things just did not work out, weather, schedule and the like. If I would have pushed to do it sooner, something bad was bound to occur. You are right about the prop. I am using a 14x8 APC I believe. It is one of the props recommended for sport use in the Saito manual. The higher pitch makes it tough to slow down. It tends to be windy here in the winter and spring so I like the idea of having a bit more thrust at idle speed so I do not have to worry about stalling if a gust happens to come up as I am landing. I rather deal with a little extra speed. I may change though. Hard to tell after only two flights. Ron
rcjon, good luck with your maiden flight tomorrow!
