RCU Forums - View Single Post - Stripped Wheel Collar removal?
Old 02-13-2005 | 09:14 AM
Stick Jammer
Default RE: Stripped Wheel Collar removal?
to make sure a collar does not fall off during flight I put a small piece of fuel tubing on the shaft to hold it onin case the screw comes loose
Ditto, I do the same. Takes two minutes and no solder required.
