RCU Forums - View Single Post - Trimming for Forward Flight
Old 02-13-2005 | 09:27 AM
RandyT
Default RE: Trimming for Forward Flight
If you don't want to spend the money you can heat the center of the subrotor with a hairdryer, and twist the subrotor blades till there is no more postive pitch. This will help with the upward lift you have at the end of your ff, or as you enter into a turn. I will take more throttle to get you heli up though. Good luck.
