RCU Forums - View Single Post - Starter Problems.
Old 02-13-2005 | 09:23 PM
Richard L.'s Avatar
Richard L.
My Feedback: (24)
Default RE: Starter Problems.
Try starting your car with a 12 volt lawn tractor battery. It's still the same voltage but won't likely have near enough cranking amps to turn the engine over.
Well, using a 4.8V 5000mAh receiver battery pack in your plane won't make your servos put out higher torque. This battery pack only gives you longer flight time.
