Did you check that back platte if it was loose it would let fuel in to the engine through the reed valve . If it still is flooded close your needle and crank it over with the head off, then put it back on and try again. Be very very carefull if you take the tank off and not damage the reed valve and gasket.
Turn on the lights before you work on the widow
[8D]
