RCU Forums - View Single Post - Mixes in aerobatics and 3d?
Old 02-14-2005 | 11:25 AM
Matt Merciez's Avatar
Matt Merciez
My Feedback: (34)
Default RE: Mixes in aerobatics and 3d?
ORIGINAL: Geistware
I heard Mike mention the throttle -> rudder mix before. I tired it and found that during landings, it is not noticable.
It also greatly improves my down lines which always looked crooked before I added the mix.
Throttle to rudder mix or throttle to elevator?
One thing I have done to eliminate the mix during landings is the assign the throttle to elevator mix to the same switch that activates the idle up. When the idle up mix is activated to ensure the motor does not die in flight, the throttle to elevator mix is activated. When I go to land, I turn off the idle up which also disables the throttle to elevator mix.
