RE: Heed help
Test launch it without the engine running.
Move the CG forward until is always dives on launch. Then, add up reflex to the elevons until it will launch into a stable glide.
Or:
Set the elevons at 3/16" up from 0. Then, move the CG forward until it launches into a stable glide.
Either method will give you a starting point from which to adjust the CG and reflex to suit your flying style.
HTH,
D
