Newbie going to build
There is nothing wrong with the landing gear, the landing gear plywood plate needs tri.stock on the inside edges esp. on grass,the light ply sig uses rips where it is glued to the plywood. The instructions are fine that comes with the covering, my preference is ultracote,I find it's easier to use, both are good,sometimes I use both on same plane.
