Aliphatic Resin or CA?
I vote for Gluit also. Its fast, bonds tight, and goes on easy. The only thing you have to be carefull of that i found was big jobs. Its just dries/cures too fast at least for my application speed on a large joint.
I probably use CA more than i should, but i am going to try and use aliphatic more after hearing you guys talk about reactions to it. I am starting to get allergic to epoxies so i try to wear latex gloves when working with it. From what i understand, with epoxy, if you work with it enough, you WILL become allergic to it. Everyone has a different tolerance though. CA glues are probably the same.
