RCU Forums - View Single Post - Grrr! Multiple problems
Old 02-15-2005 | 03:45 AM
mikenlapaz
Default Grrr! Multiple problems
I have my instructor's complete 1.2.6 disc, expansion pack, game controller and assortment of cables. I have no problem with purchasing if it will work. (Either I buy new or buy his and he gets newer version.)
I have been trying various routines trying to get this working most of day and all evening.[>:] I install 1.2.6 and expansion pack and then the download upgrade and try to load and get 'unable to locate cable' I have tried using 15 pin male in the joystick port, put adapter to USB on and tried that port. same reply.
I have uninstalled all several times. I get the above response before I download the upgrade. With the download installed it gives illegal operation and shuts me down.
This is what we are working with: (My computer skills are limited)
Computer: Win98SE. PC133 System Board, Pentium III 800 MHz, 10Gb avail memory, 256 RAM 60% free, built in Graphics system
*Onboard 128-bit 2d/3d 100MHz host interface AGP Graphics Accelerator. complies with AGP V2.0)
*Shared memory architecture allows a max of 64 MB main memory to act as buffer
*Supports high resolution to 1920x1200 16M colors, ut to 2048x2048 texture size and Virtual screen up to 4096x4096
*Supports hardware DVD Accelerator
1) I added Gamecommander to as a controller ID initially when I have it in joystick port, when I put it into USB port, computer recogized new item and added it as hardware, but it also added USB as a controller ID. Does program look for that name as a controller? When I select Gamecommander it shows it not connected if it is connected thru USB port.
HELP Please.
I also have a cord with a 9 pin female going to a male pin jack with two black insulators on shaft. The 9 pin has PRO printed on it. Have not figured just how it would connect to a TX.
No assistance from instructor as he is comm pilot and out of town for several days.
