RE: stripped muffler screw
Go to Sears or a car parts store and get a bolt extractor. Another possibility is to use a dremel with a cutting disk to carefully cut a slot in the screw head and then use a flat screw driver. When you replace the screws, consider socket heads instead, they are less likely to strip.
