RE: car/plane
i got the wing in the other room. where did you get the extra weight from? 5lbs for car. + the plane. there will be no plane engine because the front half of the plane is splinters. I have another car that is 4wd, but that engine simply wouldent cut it. so total weight I am looking at about 6lbs. My buddy said that a avastar would handle that. he said it would be patheticly poor floatability. but if he took 6 lbs and put it in a flying avastar that it would lift off.
The pices are coming together quite nicly. lots of missing pices but nothing that cant be patched up with some balsa. Also I am using gorilla glue. it seems a little heavy but other than that should it hold up?
