RE: Heed help
Hi Demon
thank you for your input,
i am using a selig, like they use on Avengers, it's semisimetrical, dont remember the number. the plane will glide in a straight path without the engine but will climb like crazy HI it running, now i measured the it and its +/_ 0.5 degrees. i even tried to put 1 degree down trust.
the thing is when i lunch it and get up there it feels like it is stalling every time i make an input. it will flop over,
the only thing i had the cg at 12.5% instead of 10 i will try 10 and i calculated the (MAC) using on line calculator
i am gono take it to school with me and see if i can get it in a tunnel.
thanks hayk
