YS63 mid-range
The screw controls the the transition between low and high throttle. If the mid range is lean, obviously you would want to open the regulator screw by some amount. 1/2 turn will produce enough change that you can easily tell the difference. If it's too rich in the mid range, turn the screw in.
Don't be afraid to play with it, it is the heart of the YS engine.
Dave
