RCU Forums - View Single Post - Aviomodelli Storch
Old 02-16-2005 | 10:36 AM
Dave 700
Default RE: Aviomodelli Storch
Be prepared to buil and build and build and ..... It will seem like you will never finish this kit.
On the plus side everything is numbered in the order that you assemble it and the pieces are well marked.
I believe the built up wing is a flat bottom airfoil and the foam wing has an undercamber to it.
You need to plan ahead on where you will mount your servos either in the kit mount with long pushrods or move the servos closer to the control surfaces. Also what are you going to use for a motor 2C, 4C or electric ?
Good luck - it makes for a nice plane.
Dave700
