RCU Forums - View Single Post - Frequency Choices
Old 02-16-2005 | 11:21 AM
Campy's Avatar
Campy
Default RE: Frequency Choices
ORIGINAL: adamtina6
Hello all,
After being out of this wonderful hobby for a long time, I am finally able to get involved again. The last time I bought a radio system was before the big change.
I was wondering about the pros and cons of the different frequencies. I hope I haven't struck a nerve with anyone here.
All opinions are appreciated.
Semper Fi
Adam
If you are concerned about the channels and don't want to spend the BIG $$$ for a transmitter with a module, check out the Tracker III from Polks.
I have a Tracker II and really like it. It is fully synthesized on both the transmitter AND receiver and the transmitter has a built in scanner. If the scanner detects interference on your channel it will not allow the transmitter to generate a signal. It is also compatible with both the Futaba/Hitec receivers as well as the Airtronics/JR receivers.
The Tracker III (8 channel ) is physically a little smaller than the II and now has a buddy box port among the new features.
I THINK the transmitter, receiver, 900 mah batteries and 1 servo are ABOUT $300
