RCU Forums - View Single Post - My ailerons don't move the same ...
Old 02-16-2005 | 03:42 PM
Prophex's Avatar
Prophex
Default RE: My ailerons don't move the same ...
ORIGINAL: MinnFlyer
It would be ok if they were going up more than down.
In your pics, we can see that they are different, but what I would rather see is a pick of the wing removed, showing the servo and torque rods at level, full right and full left
Could you post that?
Your whish is my command (for now)
I guess piper_chuck was right, the servo arms aren't te same length and the servo is also not centered (I'll explain why later):
1) Centered:
2) Centered:
3) pushing aileron stick to the left:
4) pushing aileron stick to the right:
The problem was that when I got the "kit" (it was an ARF), the connections between the servo-arms and the ailerons were not construced good. There was a big difference between them, so I had to bend one of them to the same position as the other. But in time te connection went back to their original position. [&:] (kinda hard to explain)
anyway, what should I do now ?
