Foam vs Balsa
Yes, I think foam is your best bet in this case. Balsa fuselages can be very light if the structure is relatively flat/square. Once you need all those complex/round curves of a scale fuse, the support structure/frame and skin (of balsa) will end up being heavier than foam. Bob
