ORIGINAL: MT2 Beater
A have a few questions now. Do the titanium turnbucles help at all and in what way. Also, i am going to get these eventually: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYM2&P=Z]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYM2&P=Z[/link], will i be able to use these: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTA4&P=Z]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTA4&P=Z[/link], and will the bevel gears make the diffs stronger.
Thanks a ton!!!!
The main thing about the turnbuckles is you can adjust the camber and if you have them on the steering you can adjust the toe in or out. Adjusting these affect the handling. On one of my listing I asked what people run on the camber and I never did get a reply so I will have to do some experimenting. I do not know what the MT2 comes with as far as the differential gears you are talking about. There are two types. My MT Racer came with the pot metal and I changed them with the ones you are talking about, as they are stronger then the ones that came with my MT Racer. Yes if you have the pot metal get the steal gears we are talking about. As cheap as they are it never hurts to have a spear set. I keep a spear set in my field box. These are all so an up grade for the rush if they came with the pot metal gears all so. [8D]
