RCU Forums - View Single Post - Lightning Stadium Pro Engine
Old 02-16-2005 | 08:59 PM
L2Pro-Racer
Default RE: Lightning Stadium Pro Engine
So are you saying the backplate is hitting the chassis BEFORE it reaches the mounts? Like the mounts are too short?
If so I cant see how it would work and I would go with the same conclusion you already made up. The chassis is very similar to its buggy brother and i'm sure the mounts are the same - considering the fact that the Stadium RR and the Lightning 2 RTR have the same engine.
I guess if you really want more top end you can gear up - but that really depends on how much you love your low end . The Stadium's have impressive acceleration and i'm sure you could distribute that more evenly and towards the top end.
Overall if your going to look for a new engine, a buggy engine will fit. They are also obviously bump start compatible but its up to you if you want to go that route or not.
