RCU Forums - View Single Post - My ailerons don't move the same ...
Old 02-17-2005 | 10:10 AM
forestroke's Avatar
forestroke
Default RE: My ailerons don't move the same ...
the recommended throws are usually enough for a trainer. they should already be on the conservative side. if you've dremeled it out already, have you solved your problems? a new picture of the dremel work would be good.
Do you hear buzzing sounds when you stop at the most left or right movement?
