RE: Flair Puppeteer Trust Angles
I am doing as much as I can before I start covering. I complete an operation and then assembly the whole plane just to see how it goes together. It makes it easier to correct something if there is a problem. Take a look at my last pictures and you will see what I mean. You will spend some time aligning the wings and making small changes that will be very difficult with the covering on. The last thing you want to have to do is cut into a fresh covering job to make a change.
Bassman
