RCU Forums - View Single Post - help! prop keeps falling off
Old 02-17-2005 | 12:10 PM
Bax
Default RE: help! prop keeps falling off
If the spinner backplate isn't serrated enough to grip the propeller, you'll have problems keeping everything tight. A good solution is to glue two pieces of sandpaper back-to-back, with the abrasive out. Cut it to about a 1" diameter, put a hole in the center for the propshaft, and use it to add grip between the spinner and the prop.
Helps a lot!
