Get that engine running right.
Sounds like you also have a case of high idle as well. With a 10x6 prop on a 40 sized trainer using a 40 sized engine, you shouldn't be climbing at idle (unless your trainer is sub 4 lbs). You want your engine to idle as low as possible without going deadstick or trim the idle down as far as possible on your landing approaches.
