RE: take a look at these tires
The speed hawgs are roughly the same diameter of the stock tires. You should be able to do a direct swap. As far as matching the tires, I did. The ribbed tires will burn off pretty fast driving on pavement. Just an observation, but they are designed for loose, or low traction surfaces. Not pavement.
