RCU Forums - View Single Post - Operation R/C
Old 02-18-2005 | 09:26 AM
  #42
Greg Covey's Avatar
Greg Covey
Default RE: Operation R/C
Laine,
I shipped the Zagi Tazz to the APO today. It has the brushless motor and ESC but no battery so you'll be running on pure Lithium power!
If you recall the pictures from my review, the ESC comes fully wired with the Dean's Ultra plug. This is a nice plug-in-play feature of the Tazz power system. The motor is also ready to plug into the ESC, so, if the direction of rotation is wrong, you can just swap any two motor wires by easily unplugging them. This is best tested before you install the prop. Also, do not run the motor more than half throttle without the prop attached.
Let me know if you will anything else. I was thinking that you may need a charging cable to go from the Kokam charger to the Dean's Ultra connector on the Lithium battery pack. I'm not sure what is supplied with the charger.
