RE: 9303 Heli Throttle kill using Trainer switch?
You should be able to do this. Set up a program mix, and set the master to BUTN, and the slave as throttle. Then set the rates as needed. The mix will remain active however until you release and flip the switch again, but if you are using it for a kill function that shouldn't be an issue.
