RE: Am i missing anything.
Usually when engines are rated for RPM's, that is the max rpm, and you don't want the engine to be pulling that on the ground. The engine will unload in the air. If you were getting 11,000 on the ground, then I guaratee you were getting over 12000 in the air.
