RE: Mini Olympus Gearbox hangs
hercules,
Just a couple of thoughts,Does the motor run ok separate? Are the gears running true on thegearbox? From the side no up and down movement, could be a bad shaft or, gear not on shaft straight, causing a bind.
BJ
