RCU Forums - View Single Post - CA Hinge Question
Old 02-18-2005 | 11:39 PM
rb4123's Avatar
rb4123
Default RE: CA Hinge Question
I think you may have it 90 degrees out. It sounds like the indent you are talking about should be perpendicular to the hinge line to allow the adhesive to flow in the slot. Which way does the indent run, length wise, or width wise? It should rub length wise, so that it is inserted into the hinge slot.
