New Impact Electric Setup
Hello,
My new Impact arrived yesterday. Now it is decision time I have decide to put an electric setup in it but am unsure which one. I can go for the Hacker setup or the plettenberg setup.
I have two concerns:
1. I may not be able to get the hacker setup under 5kg especially if I am adding weight to strenghten up the tail and fin as discussed in other threads.
2. Plettenberg setup may not have as much power as the hacker.
Other factors:
The plettenberg setup is ment to be quiter
There are no gears in the motor
I am undecided as I have seen alot of people goiung with the plettenberg setup with Impacts as it is a lighter setup. I am afraid I will have to lighten up the impact too much to get it under 5kg with the Hacker setup.
I would be interested in hearing any suggestion or comments about this?
Would also like to hear you comments on:
Plettenberg V's Hacker Motor
Schultz Speed controller v's Hacker Master 90
Emcotec Batteries v's Thunder Power.
Also how are you guys charging in these 10s3p 6000mah at the field and at home from the mains.
I know I am asking alot of question but hope you guys can help me make my mind up.
Thanks for your help,
