RCU Forums - View Single Post - HELP!! SuperTiger Gas Conversion Fuel Flow Problem.
Old 02-19-2005 | 04:28 PM
DDriver
Default RE: HELP!! SuperTiger Gas Conversion Fuel Flow Problem.
Hi Chad,
I am using the SuperTiger G.90 standard carb (Twin needles for hi-speed/Mid range and low end/idle needle.
Although I am using the CH ignition, back in Nov 99, Gerry Yarrish of Model Airplane news did a preview of the Pro Soark Ignition on a SuperTiger 90 and it seems that the SuperTiger engines from .90 & up have twin needle carbs that work very well with the gas conversions.
I origionally had some fine bubble leaks around the hi speed needle, but teflon tape wrapped around the threads fixed that completely.
DDriver.
