RE: You will crash !!!
OK, back on task here. Epoxy will not (obviously) wick into the wood of the wing, so therefore any attempt to epoxy CA hinges would lead to a build-up of epoxy at the joint. This would make a stiff, inflexible joint. Period. Why would you epoxy CA hinges? They are labeled CA hinges for a reason!
