RCU Forums - View Single Post - You will crash !!!
Old 02-20-2005 | 06:25 AM
  #52
Prophex's Avatar
Prophex
Default RE: You will crash !!!
ORIGINAL: 2slow2matter
Apparenty you WOULD dissagree with "no one really understands," because from your tone, you're obviously the only one that really does understand--but that's because you read it all on some website? I never said i was right, and I never said you were wrong, but you insist that I'm wrong. I don't think I'm totally wrong or off base, I'd bet that I have a higher understanding of fluid dynamics than you. you've never said what your background is.
OK, you're right, this is off subject, and this is now becoming an argument, which I didn't want. Some people have a hard time discussing things without calling the other person wrong. Sorry we couldn't have that sort of discussion.
OK, back on task here. Epoxy will not (obviously) wick into the wood of the wing, so therefore any attempt to epoxy CA hinges would lead to a build-up of epoxy at the joint. This would make a stiff, inflexible joint. Period. Why would you epoxy CA hinges? They are labeled CA hinges for a reason!
OMG, my manual said to use epoxy:
