RE: COX Part
I was out of the country when the RR1 came out but doubt if I would have bought one anyway . Maybe I should have said that I have what looks like a new RR1 crankshaft that I would trade for a tank . I often wondered how the induction was set up & found out it is nothing new . Several older engines used the rear rotary drum induction but none that small. The engine was flown & the over flow tube broken off , then the tank in that area was ground down so they could try to solder the hole up ,didn't work. The tube I can make or pull from a Golden Bee or what ever else had the tube but the ground area is a tough one . May just replace the tube & sell it to some one that just wants a runner. Will these work better with a TD head ? Thanks , MAX H.
