RCU Forums - View Single Post - HELP!! SuperTiger Gas Conversion Fuel Flow Problem.
Old 02-20-2005 | 09:39 PM
platero's Avatar
platero
Default RE: HELP!! SuperTiger Gas Conversion Fuel Flow Problem.
if you have bubbles in the fuel line this bublles come inside from two possibles sourses. one is the atmosphere an other is the presurized tank, the first can take place from lines or valves, the second from the line inside the tank, not more to think, bubbles come in in low pressure lines only. You can take the the complete system tank and lines to sink it in water and to give pressure him.
